Between work and family I have not had much time for the project, but did manage to carve out a few hours this weekend. Worked on the panels. Found unused power run from the barn to the house. Remember seeing in years ago when I was crawling under the house. Found it again and now have the panel power running over that line. This gets rid of the cables laying across the yard.
I also found some time to work on the monitoring board. Was able to get the power poles mounted to the board, current sensors (ACS715) wired up and a voltage divider circuit with adjustment pot on the board.
I also able to connect all the signal pins to various wires. Now for some more testing.
Gary
