more time
A project log for Web based solar panel monitoring/managment
Arduino enable web server to monitor a small solar array and power management systems.
garyGary 09/13/2014 at 23:540 Comments
Was able to get the project mounted in  a case. The cut outs are a bit messy but it will work. Best I could do with the dremel tool..
