Online
A project log for Web based solar panel monitoring/managment
Arduino enable web server to monitor a small solar array and power management systems.
garyGary 09/24/2014 at 00:540 Comments
Project has been online for a few days and starting to get some data captured. The current portion of the circuit seems to be working fine, but the voltage seems to never get below 11v on all 3 channels.. When there is sun the panel voltage go up but non of them tend to go below 11 volts. I suspect some cross talk. Will have to look at how to fix this....
