PiFM and the Multicore Pi's
A project log for Anyfesto
Any manifestation of a meeting - in the schools or in the streets - is going to need clear communication. Anyfesto helps that happen.
tomwsmftomwsmf 02/04/2016 at 04:381 Comment
02/02/2016
Stop, start, restart, restop, restart.
The multicore RPis do not work well or at all with the PiFM code. Some folks are attempting to fix this. I nthe mean time I have moved the FM section of the project to a less mobile solution but one that works for what I am using it for.
The PiZero seems to run PiFM fine. As I have just one and it is on use on another project it might be a while before I get to reintergrating PiFM into Anyfesto.
tomwsmf wrote 02/04/2016 at 05:05 point
One item I am working with is the FM Module from Adafruit. It is small, breadboard friendly and will fit nicely in the cases I am using.
Initial test are good though I am not all that happy with the range.
Adafruit has done a lot of the leg work in getting code snippets for most of the functionality.
https://www.adafruit.com/products/1958
