AnyfestoCHIP - now working
A project log for Anyfesto
Any manifestation of a meeting - in the schools or in the streets - is going to need clear communication. Anyfesto helps that happen.
tomwsmftomwsmf 06/13/2016 at 02:300 Comments
After a long time in the todo pile I got around to working on it this weekend.
These steps will walk you through setting up an AnyfestoBox on a CHIP http://docs.getchip.com/chip.html Anyfesto on a CHIP 9$ computer. N.B. This set up will use CHIP's wlan1 for the captive portal,dnsmasq, etc etc. wlan0 is left free to connect to backhaul, the intertubes or whatever network you may want. No bridge has been set up by default. Lots of ideas for use of this.
Parts List
   CHIP - https://getchip.com/pages/store - $ 9.00
   USB Stick 32GB or Bigger - Many Sources - $20.00 - upward
   LIon Battery 3.7V 2500mA - https://www.adafruit.com/products/328 - $29.50
   5V 2.4A 6' MicroUSB Cable - https://www.adafruit.com/products/1995 - $ 7.95
The up to date full set of instructions is housed over on the Anyfesto GitHub
