LOKI 4G (Locate Observe Krack Isolate) 4th Gen
This is version 4 of LOKI. LOKI is a pentesting payload piggybacked on a 3D printed Drone with machine vision.
Update 8/26/15: I have been working on several project simultaneously. This helps with my Hackaday Prize Solar Drone by testing systems on multiple platforms. I am updating pictures and project logs currently.
We are getting near the end of prototyping of our second generation quad drone called LOKI. While it is capable of many things, search and rescue are one of the more benign activities that LOKI is capable of performing. I will give a brief overview of the hardware and then we will talk about scenarios that have been tested and things we believe we have not achieved yet with this drone tech
LOKI
3D printed Airframe and basic hardware:
Spyda DJI Arm compatible 3mm Solid Slotted Body Plates (2)
http://www.thingiverse.com/thing:160607
Spyda DJI body
http://www.thingiverse.com/thing:230558
Spyda Custom DJI arms with integrated landing gear holder.
Custom clear feet for landing gear
Custom Battery Holder
Custom Ubiquiti Bracket
Custom Antenna Holder
Custom Odroid 3 standoffs
Custom AUAV X2 Mount
Custom Spectrum Landing Gear Mount.
Custom Mobius Gimbal
*insert link for LOKI build
10mm x 4.5 inch carbon fiber tube
M3 x 10mm hex screws
LOKI Electronics
AUAV X2 autipilot
NEO 6H GPS Compass Module
Odroid U3
Ubiquiti Pico Loco M5 stripped and modified
Alfa AWUS036H
Power Distribution Board
BEC
Buck/Boost Module
POE injection Module
3s 5000 mah battery single or double
Spektrum Satellite Receiver
20 amp esc (4)
2213 920KV motor (4)
Gimbal Electronics
Alexmos 2 axis BGC
2206 80T 140KV gimbal motor
2212 80T hollow shaft gimbal motor
Mobius Webcam
LOKI Software
ArduCopter firmware
OpenCV
MatLabs
Kali Linux
Maltego
Various python packages
Gstreamer
Ground Control Hardware
JR9303 with Spektrum Module
Odroid XU3
10 inch Lumineer FPV display
3D printed display bracket
Server Hardware
Odroid XU3 (7)
  • LOKI 4G Overview
    tlankford0108/26/2015 at 06:24 0 comments
    LOKI 4G
    Locate, Observe, Krack, Isolate
    • 500-900mm Wheelbase
    • 25 minute to +1 hour flight time
    • 640 Thermal Sensor with 160° viewing angle
    • 10X Zoom 1080 HD Camera
    • 1 mile HD Video and Digital Control Link
    • Advanced Ground Station Compatible
    • Integrated Vibration Isolation
    • Embedded Advanced Robotics Computer
    Industry Use:
    • Radiation Detection (optional)
    • High Grade Survey (optional)
    • Agriculture Monitoring
    • Solar and Wind Inspection
    • Flare Stack Environmental Testing (optional)
    • Cinema and Photography with 3 axis gimbal (optional)
    • Search and Rescue
    • Livestock Population Survey and Monitoring
    • Hunting Stock Census
    Military/ Intelligence Use:
    • Ship Inspection
    • Squad Level Real Time Situational Awareness
    • UTM Guidance Compatible
    • Advanced Signal Capture (optional)
    • Day/ Night Operations Capable
    • Intuitive Lightweight GroundControl
    • Multitude of Color Patterns
    • Parachute Fall Arrest
    • Quick Adjust COG for Fast Payload Swap
    • Compact Folding Storage
    Advanced Design Techniques
    Designed, Manufactured and Assembled with 100% Renewable Energy
    Manufactured and Assembled in the USA
    Custom Electronics Design and Placement
    **All Photos, Rendering and Designs are wholly owned and produced by Aerial Vista and its parent company The Lankford Group. Any use without the express consent or license of the above named entities is strictly prohibited
View project log
EngineerAllen wrote 02/17/2017 at 00:29 point
looks super heavy!
