Raspberry Alarm Upgrade
In this Project, my 20 years old alarm system gets an upgrade, email and SMS warnings replace the old phone calling notification.
My house is fitted with a 20 years old alarm system. Unfortunately the phone warning system isn't working with our new internet provider. I thought that it was worth upgrading instead of replacing the whole setup. For that I designed a Raspberry pi "hat" with all the interfaces and components I needed.
Project definition
Even though the alarm system is pretty old, its design is hacker friendly. The motherboard has a 12V power output that can be used for future extension cards. This is the power output I used. When something is detected, the siren is triggered by an output and the voltage drops from 12V to 0V.This is very convenient for my project !
The system must be able to notify me in any conditions, for that reason I wanted three warning types:
-Email : Even if I don't have my phone I can get notifications on my laptop
-SMS : The most convenient way to notify someone
-Call : At night my laptop and my smartphone are turned off, the only communication available is my fixed-line phone
Interfaces and Components
The first type of notification is easily doable with Python on the Raspberry pi. The two others will be handled by a GSM modem.
For the modem I used a SIM900 : a popular component with a great online community support.
I needed two power supplies, 5V for the Raspberry pi and 4V for the GSM module. I used two TI PTN78000W series because they have a high efficiency and great output current.
The last and more important interface is the siren trigger. I used optocouplers to step down the voltage to 3.3v and protect the Raspberry pi.
  • 1 × Raspberry Pi B+
  • 1 × Sim900
  • 2 × PTN78020 Power Management ICs / Power Supply Modules
  • New board soldered and code available
    Brieuc du Maugouër06/28/2015 at 20:06 0 comments
    I got some time to solder the board and push some code. I haven't fully tested the board yet. It appears that you cannot power the raspberry pi 2 from the GPIO header, thus the board might not be 100% compatible with it.
  • New PCBs just arrived
    Brieuc du Maugouër06/19/2015 at 09:23 0 comments
    I received this morning the new version of the PCB from China. If this version doesn't have errors, I will release all the design files.
  • New version coming soon !
    Brieuc du Maugouër06/16/2015 at 14:43 0 comments
    Just graduated !! Aside from looking for a job, I'll have some time to update this project and release hardware design files as well as software !! Stay tuned !
  • Brieuc :
    Brieuc du Maugouër01/25/2015 at 01:39 1 comment
    24/01/2015
    Done :
    The warning system is implemented and working
    To do :
    Correct software bugs
    Troubleshoot the battery voltage monitoring
    Upload code examples
    Upload PCB schematics and layout
    New PCB
    - add capacitors next to the Module
    -change the SIM card slot location (the sma connector is blocking the slot)
    -new battery watching interface
    -improve component placement
View all 4 project logs
