Still going
A project log for Home made 3D printer
Another 3d printer made from old printer and scanner parts
SaabmanSaabman 05/27/2019 at 23:030 Comments
it’s been over 4 years since I put this together and it’s still going. I’ve added a heated bed and a diagonal support from the top of the frame to the base to increase stability the construction is somewhat not rigid. The support has improved the quality of the prints.
I would like to get finer resolution which is not possible I the current set up as the y axis has an enormous amount of play - it was a backlight carriage from a flatbed scanner so only intended to travel in one direction and accuracy was not critical.
