Github netduino code
A project log for 360 Degree LIDAR-Lite Scanner
I took two LIDAR-Lite laser range finders and mounted them atop a 3D printed, 360 degree continuously rotating frame, to scan any area.
jason-woodJason Wood 02/02/2015 at 00:110 Comments
Github with Netduino code to read the MODE PWM pin's measurements.
https://github.com/WoodRobotics/LIDAR_Lite_PWM_Fix
