Ongoing Progress
A project log for ESP8266 Breakout Board
A simple breakout and programming board for the ESP-12e module
sukasaSukasa 08/18/2018 at 16:240 Comments
Wow, 7 months.  Need to update more.
In that time there have been a few updates.  A pair of swapped pins on the original footprint, optimized/cleaned-ipup layout, and the addition of three resistors to the ADC pin means the breakout is far more robust than before. I have been using it for a few network sensors around the apartment now and am quite satisfied with the revised design.
All that remains is to do some final cleanup and documentation in the EAGLE design and post it.
