Improved Honda Key & Key Fob
I still didn't like the size of the Honda key, so I separated the key and the remote module
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
While I had already designed a replacement key, I wanted one with a separate key and transmitter module. The module is just the remote transmitter.
Start with a Honda key with a cracked housing. Print all four parts, and add (6) M2 x 8mm long socket head cap screws, (2) M2 x 3mm long socket head cap screws, and (6) M2 hex nuts. There is a pocket within the head of the key to insert the anti-theft chip. The remote control door lock button housing fits within the fob.
