More changes, and some testing
A project log for Bench Power Supply
Designing an open source, modular bench power supply to rule them all.
the-big-oneThe Big One 03/16/2015 at 05:082 Comments
After a lot of research and experimentation, I think that I have come up with a design that meets most of my goals. I use the LM317 family (LM317, LM338, and LM337) for regulation of both voltage and current. This design allows analog control of both voltage and current setpoints, so that you can connect a MCU and a DAC if you want to, or you can just use a potentiometer. The modular design allows you to choose to not populate the current limiting regulator + associated op amp if you do not care about adjustable current limiting. Likewise, by bridging some resistors and leaving out others, you can change the same board into a negative regulator with the LM337.
I have a version currently working on my breadboard: you can set both voltage setpoint and max current using a MCU + DAC, and it keeps the output within those limits regardless of load. (The current limit is not yet programmed in, so I don't have actual valid numbers showing for the values; however I can change the DAC output and observe the limit changing, so I can tell that it is working. Getting real calibrated current limiting is the next step). I also have not yet tried it with the negative version (LM337), but will do so before ordering the board.
Testing has been going very well with this version. Line and load regulation are very clean at all tested loads (up to 3.5A).
I had to make some concessions from my original design goals:
A schematic is included below. I would greatly appreciate any comments on this design.
I will try to post more details over the next few days as I do more testing.
Cheers
Michael Vowles wrote 03/16/2015 at 12:28 point
Great to see the design evolving mate! Keep it up.
The Big One wrote 03/16/2015 at 16:59 point
Thanks, appreciate the comments!
Cheers
