We use a Bluetooth module to receive the signal sent by the Bluetooth spp app in your android mobile!!(You can download it from play store). Since, the motto of the paper is to prepare a dynamic bot, for which we need to design a code which can move the bot in all the possible directions. After the code is designed, to meet our requirements we need something that can store and functions the code for which we use a microcontroller. (The Bluetooth module will be interfaced with the micro controller where most of the work will be completed). Now we need a device which can automatically operate up to certain limit for a given command with the help of error sensing feedback for which we use servo motors (to run the wheels).
surya sai Manisetty
Polectron
Anıl Aras
