Digital Dice Roller
A very simple dice roller that I made to familiarize myself with MSP430 microcontrollers. It uses a some transistors and 7-segment displays.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
The first thing I made with my Ti Launchpad. It's just a simple dice roller with 2 buttons; one for 6 sided, and one for 20 sided.
The only trick here was the way the two displays were multiplexed, because of the lack of IOs. with both an NPN and PNP transistors, I was able to source current to one at a time depending on whether the bases were pulled high or low.
