New code, support for shift registers
A project log for 2Wire (I2C) From Blocks of Light on an LCD Screen
2Wire (unidirectional I2C) coms from HTML5 to hardware via blocks of light on the screen.
james-newtonJames Newton 02/02/2022 at 18:100 Comments
Updated versions of this code are also available, using better methods and also supporting shift registers.
These are untested and I would very much like your feedback on them. If you see bugs, please let me know. The silence on this project has kept me from devoting any time to it, but please know that if you ask, I will respond and make corrections, etc...
I'd really like to work on a design for a little board to interface between either a shift register or a microcontroller. My idea is that perhaps one board can be made to serve both functions. e.g. You populate part of the board for I2C, and you populate a different part for a shift register.
The other option is to do two separate boards, in which case I would do the I2C to uC version first. It would be something like my RC Servo to uC adapter board:
https://hackaday.io/project/181972-rc-servo-adapter
but with locations to mount the electronics and 2 light sensors, either directly to the PCB or via wires. (note to self, remember to include strain relief holes. I always forget those).
If a final circuit for a shift register is tested, then I'll try to include a 3rd sensor and use one edge to pinout for a shift register chip.
