Hackaday.io Hackaday.io
Sign up Log in
ARCS: arm robot control suite
Open-source software to set-up,control and program robotic arms built with arduinos and servomotors
fabienFabien
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.6k views
0 comments
632 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
1.6k
0
632
8
Team (1)
  • fabienFabien
Join this project's team
  • Personal website
  • Video demonstration
  • CrowdFunding Page
hardware
Software
completed project
arduino arm ROBOT processing 3dprint robotic servomotor
Related lists
Robotics
Robotics
This project is submitted for
  • Hackaday.com Tip Line
This project was created on 02/04/2015 and last updated 6 years ago.
Description
The aim of this project is to provide a simple and flexible platform for the operation of a 3d printed robotic arm. for this project I creat a firmware for arduino boards that communicate over usb or bluetooth (serial) with a computer. (maybe later with android devices) -it support speed management of the moves -stores in eeprom calibration values for servos -accept serial orders and give feedback (based on a timer...) I also created the Arcs software written with processing. actually it can: -move the robot by sliding cursors, joystick, keyboard. -move the robot by executing a sequence file. -create movement sequences and store/load it. -read/write eeprom values -move servo motors by pwm values (for calibration) -read/write XML files for lanquage and configuration storage. -display its interface in french or english, and virtually all other languages by simply translating a xml file I mark it as completed as it works well as it is now, but It is made to be growing.
Project Logs
Collapse
  • Crowdfunding is going on!
    Fabien • 04/24/2015 at 13:08 • 0 comments
    Check this link to help the project and get yours!
    there is also a 3d printer to win...
    http://www.kisskissbankbank.com/arcs
View project log
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "ARCS: arm robot control suite", please tell us the reason.
Send message
Remove Member
