Hackaday.io Hackaday.io
Sign up Log in
The Lan table
A table with integrated power hub and gigabit networking
ysteinØystein
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
12 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
678
0
12
4
Team (1)
  • ysteinØystein
Join this project's team
hardware
completed project
This project was created on 02/05/2015 and last updated 10 years ago.
Description
Just wanted to share my recent project. I wanted a table with integrated power and networking for 8 people. No table that I could find fitted my specifications and I wanted to build it myself anyway. So me and my friends got to work an made a Lan table: Some specs: 3.05 meters long 1 meter wide Weights 80 kilos space for 4 persons per side There a dedicated 76 by 50 cm area for each person Each person has 4 power outlets and one network port Its equipped with gigabit ethernet. it uses cat 6 network cables. It has a lockable power connector at the end. Americanized specs(and yes I did use google): 10 feet 5⁄64 inches long 3 feet 3⅜ inches wide Weights 176.36 pounds space for 4 persons per side There a dedicated 29.92 by 19.68 inches area for each person Each person has 4 power outlets and one network port Its equipped with gigabit ethernet. it uses cat 6 network cables. It has a lockable power connector at the end.
Project Logs
Collapse
  • Stable as a table
    Øystein • 12/05/2016 at 09:55 • 0 comments
    The table has been in consistant use for 2 years now. Still going strong!
View project log
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Silent and powerfull gaming PC
Project Owner Contributor
Silent Steam BOX
jerpeleajerpelea
Building a Bench Lab Power Supply using an ATX Power Supply from a PC
ATX Bench Lab Power Supply
orlando-zenOrlando Zen
The 2016 Hackaday Prize
The modular, easily disassembled, yet sturdy executive style Command Center Desk
Die Brücke
yonghanYonghan
Turn discarded (old) laptop power brick into bench variable DC power supply.
Power supply from discarded laptop adapter.
sudarshan-patilSudarshan patil
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "The Lan table", please tell us the reason.
Send message
Remove Member
