CC3200/3100MOD Breakout Board
a simple breakout for CC3200MOD or CC3100MOD
After quite a long time, Ti finally have CC3200 and CC3100 module version. And it's time to build a breakout for futher dev( although it seems that everyone is dev wifi using ESP)
So this breakout can handle both CC3200MOD and CC3100MOD,
for CC3200MOD, I've add a CP2102 as UART to USB, hope can be use with energia .
(by the way, I forgot to add a switch for CC3200MOD boot from UART upload mode
to SWD debug mode on this version
and this breakout have all the pins on CC3200MOD, and breadboard compatible
( Although it cover almost all the rows
for the ANT, the PCB can use both chip ANT from TI's EVB or U.fl socket compatible ANT.
finally, the board has a LDO for power supply.
  • 1 × CC3200MOD/CC3100MOD wifi module
  • 1 × PCB Electronic Components / Misc. Electronic Components
  • 1 × CP2102 USB to UART IC
  • using Energia as IDE
    Will Whang • 02/10/2015 at 13:19 • 3 comments
    Energia supported CC3200 launchpad, and the upload method is using onboard FTDI chip
    to do the reset, since I hate FTDI, I'm not going to use the same chip on my PCB.
    but that makes this breakout can't auto reset.
    So the upload process become an old Arduino, after uploading then press reset, and it will upload program to CC3200, but the debug stage will fail, I'm finding a way that when CC3200prog.exe send a break signal, CC3200 will auto reset, hope I can do it with passive components rather then some atmega16U2 as UART to USB.
  • Testing completed
    Will Whang • 02/09/2015 at 09:21 • 0 comments
    So by using Uniflash to flash and energia to compile, I can now using CC3200.
    but the PCB have to do some modification
    first, adding a switch and two 2.7K resister to choose between UART Upload and Normal mode.
    second, adding a tact switch for reset function.
    the whole process is:
    1. Switch to UART Upload mode
    2. select the bin file
    3. click program, and when it tells to reset, press the reset for about 3 sec
    4. finish
    here is the example of AP mode.
    and Serial echo example in the SDK.
  • Soldering complete
    Will Whang • 02/07/2015 at 12:36 • 0 comments
View all 3 project logs
Benjamin Prescher wrote 11/06/2019 at 20:24 • point
Nice one! I was looking for something "more" than an esp8266 / esp32. I've found something similar on aliexpress: https://hackaday.io/project/168326-cc3200-breakout-alternative-to-esp8266 and tried it out.
Roman wrote 02/16/2016 at 23:45 • point
Hi, I have notices you changed the shape and size of the trace going to antenna. It is different from the one on the LAUNCHXL board. Did it affect RF performance in any way?
Will Whang wrote 02/18/2016 at 09:30 • point
Yes , it will affect RF performace, not only I've change the trace & size
PCB layer also changed from 4 layer to 2 layer, definally degraded the performance
Roman wrote 02/19/2016 at 04:31 • point
Still looks  pretty cool
Will Whang wrote 02/24/2015 at 11:55 • point
sorry but I am not going to sell the PCB, but the files are on Github,
so you can make one for your self.
I think the current breakout board is adequate for CC3100MOD but not CC3200MOD
because of lack of reset button and auto reset.
Mikej wrote 02/23/2015 at 18:45 • point
I got two samples of each 3200 & 3100 thinking I was getting eval boards. Are your protoboards available to purchase? - Mike
