Casing [Finished making case]
A project log for Portable Raspberry Pi gaming handheld
Made from a Raspberry Pi 2 B, a 4,3" TFT screen, a powerbank and a modified SNES controller.
lumorLumor • 12/29/2015 at 02:28•0 Comments
Spend allot of time perfectly aligning the buttons so they feel 'right' when pressed, i didn't leave myself much room when i designed the case so it was difficult. I also aligned the screen with the front plate. The image is still not perfectly aligned on the screen, i need to configure that in linux.
It's pretty much a functional device now but i still need to mount the speakers and shoulder buttons.
I figured it was kinda bad that i don't have a power indicator, the powerbank has indicator leds so i might have to make a hole to see those.
