PCB layout for Rev. 2
A project log for Balance Wheel
Balance a 40mm steel ball on a lasercut wood wheel
manuel-kastenManuel Kasten 02/15/2015 at 13:440 Comments
The PCB layout for Rev. 2 is more or less finished. This should be Arduino Leonardo compatible, motor driver and transistor (for lamp dimming) included. I managed to fit everything on 50mm x 50mm (so I can get really cheap prototypes from itead):
I also created a repository for Rev. 2 and uploaded the PCB layout: https://github.com/Draradech/balancewheel
