Just a small update
A project log for STM32F030F4P6 breakout board
Not as bulky as the nucleo boards, after all.
christophChristoph 06/16/2015 at 20:130 Comments
I actually found time to redesign my reflow oven controller and to assemble a test board with the new layout:
The extra clearance between the 0603 parts to the right really helps during assembly. The LED (an Osram SmartLED LA L296) is still a bit too bright with a 330 Ohm resistor.
I also updated the link to OSH Park.
