BOOT0 issue
A project log for STM32F030F4P6 breakout board
Not as bulky as the nucleo boards, after all.
christophChristoph 11/04/2015 at 09:100 Comments
As david pointed out in the comments, BOOT0 should be pulled low to boot the application. For now this has to be done on the breadboard because the PCB doesn't include a pull-down resistor. I hope to fix this in the next PCB revision without having to use smaller (0402) parts.
