WHAT NEEDS TO BE DONE!
A project log for One Bad A$$ Power Inverter
I came across a schematic of a reverse engineered 12V - 120V AC Power Inverter. So I started to make the "ONE BAD A$$ POWER INVERTER.
fredkonofredkono 03/12/2014 at 00:240 Comments
Basically the only thing holding me up on this project is -
1. Some kind of cool box, cabinet or housing to put this in.
2. Winding the transformers. They are 6 turns center tapped primary and 52 turns secondary.
3. Getting the IRF1404 Mosfets, Fuses, Fast Diodes and some capacitors.
4. Working on my Radio restoration lately...
