Smile Station
Photo booth that is very portable and configurable.
This is a photo booth built from a raspberry pi and camera board. No printer on it to make it better at being portable and less problematic. It has a 7 inch screen, red lite button, a bunch of 3d printed parts, hacked router for uploading to Gmail, Facebook, Flickr, and/or downloading with samba... Fun Times...
I have finished this photo booth and it works great. As of now I have scripts set up for up-loading and stand alone . I can control it from a secondary computer with putty and Winscp or from the screen with the wireless keyboard. I don't have photos of every thing but I did get photos in different stages that can be used for reference. I will work on getting more or better photos on my next projects....
  • 1 × Rapberry pi 512 model
  • 1 × RPI camera board Not the infra type
  • 1 × sd card any type that works
  • 1 × 7 inch lcd screen from ebay migh be better to get a hdmi one I did not
  • 1 × lighted red arcade button any off ebay
View all 16 components
  • 1
    Step 1
    First I got the RPI set up with the latest and greatest Raspian. Make sure that you up-date up-grade and set the GPIO and Camera in raspi-config. This site has all the information that I started off with even the code I used to get it working at first (camera.py I added stuff to this code to get it to do what I needed it to do I will add this info later.
    http://contractorwolf.wordpress.com/raspberry-pi-p...
    Make sure that you get the button working that is important.
  • 2
    Step 2
    On this next link is where I got the info for sending the photos taken with its own email account .
    http://mitchtech.net/connect-raspberry-pi-to-gmail...
    I tested it by copying the script to send attachments in to the python editor on the rpi by first opening the python editor and then open a new scripting page so you can paste in the whole script at once and run it ( make sure you fill in all the necessary info first or it will not work email address,  where to send it to, etc) I have a dedicated email address for this project you don't have to but it might be best. I will post my script in the next step (3).
    I also started working on the body of my photo booth. I am using a concrete forming tube, blue foam board, and PVC pipe from Lowes for the body. The tube was 4' tall by 12" round. I cut 12" off the 4' tube to give me a head. The photo below shows how I was headed. I used the head as my blue foam templit for cutting.
    You will need at least 4 blue foam board round cut outs. In this photo I noticed that it might be more stable with the head laying side ways and it looks better.... so this is the way it stayed.
  • 3
    Step 3
    Well in this step I will focus on the code and getting it to work with Facebook and Flickr ....
    #!/usr/bin/env python
    # this file is run using this command: "sudo python camera.py"
    # python must be installed, and you must call the command while
    # you are in the same folder as the file
    from time import sleep
    import smtplib
    from email.MIMEMultipart import MIMEMultipart
    from email.MIMEBase import MIMEBase
    from email.MIMEText import MIMEText
    from email.Utils import COMMASPACE, formatdate
    from email import Encoders
    import os
    import RPi.GPIO as GPIO
    import subprocess
    import datetime
    # set up the pins
    GPIO.setmode(GPIO.BCM)
    GPIO.setwarnings(False)
    GPIO.setup(24,GPIO.IN)
    GPIO.setup(23,GPIO.OUT)
    GPIO.output(23, True)
    # setup variables
    USERNAME = "Youremail@gmail.com"
    PASSWORD = "emailpassword"
    count = 0
    up = False
    down = False
    command = ""
    filename = ""
    index = 0
    camera_pause = "3000"
    print "Raspberry Pi Camera with Buttons"
    def takepic(imageName):
    print("click")
    command = "sudo raspistill -o " + imageName + " -q 100 -t " + camera_pause
    print("After your photo is taken please give it a sec to send and save")
    os.system(command)
    def sendMail(to, subject, text, files=[]):
    assert type(to)==list
    assert type(files)==list
    msg = MIMEMultipart()
    msg['From'] = USERNAME
    msg['To'] = COMMASPACE.join(to)
    msg['Date'] = formatdate(localtime=True)
    msg['Subject'] = subject
    msg.attach( MIMEText(text) )
    for file in files:
    part = MIMEBase('application', "octet-stream")
    part.set_payload( open(file,"rb").read() )
    Encoders.encode_base64(part)
    part.add_header('Content-Disposition', 'attachment; filename="%s"'
    % os.path.basename(file))
    msg.attach(part)
    server = smtplib.SMTP('smtp.gmail.com:587')
    server.ehlo_or_helo_if_needed()
    server.starttls()
    server.login(USERNAME,PASSWORD)
    server.sendmail(USERNAME, to, msg.as_string())
    server.quit()
    while(True):
    if(up==True):
    if(GPIO.input(24)==False):
    GPIO.output(23, False)
    print "BUTTON DOWN PRESSED"
    now = datetime.datetime.now()
    timeString = now.strftime("%Y-%m-%d_%H:%M:%S")
    print("request received" + timeString)
    filename = "photo-" + timeString + ".jpg"
    takepic(filename)
    sendMail( ["facebookmobleemailadd@m.facebook.com"],
    "test set up for photo booth",
    "Test picture attached",
    ["/home/pi/photos/photo-" + timeString + ".jpg"] )
    print "Ready"
    up = GPIO.input(24)
    count = count +1
    sleep(.1)
    # this is never hit, but should be here to indicate if you plan on leaving the main loop
    print "done"
    It does not look as good on here as it does in IDLE and I dont think you can copy and past it. so I am in the work of getting a place I can post my files for links to them like for here at hack a day.
    I will use it to show where to make changes to make this work. Oh I did not make this script I just copied pices of it to smash it together to make it work for me.
    # set up the pins
    GPIO.setup(24,GPIO.IN)    <- Button input
    GPIO.setup(23,GPIO.OUT) <- Lite on the button
    GPIO.output(23, True) <- turn lite on
    # setup variables
    USERNAME = "email@gmail.com" < -you need to put you email you set up        for this thing here
    PASSWORD = "password" <- password for that email address
    count = 0 <-starts photo count at 0
    up = False
    down = False
    command = ""
    filename = ""
    index = 0
    camera_pause = "3000" <- how much time it will preview
    Next
    command = "sudo raspistill -o " + imageName + " -q 100 -t " + camera_pause <- ok this is the command that is sent to take the photo. (I know now htey have this worked out to do this in python with out using os.system .) you can add options on here from the camera info like polerize of sketch. this is just like typing it in the terminal prompt.
    Emailing
    sendMail( ["the emailtheygiveyou@m.facebook.com"], <- they will give you a        email to send to        Flickr does the        same thing
    "test set up for photo booth", <- this can be any thing I see it on facebook as                                                        the photo comments. I have thought to use                                                          "photo-" + timeString + ".jpg" to see what                                                               happens .
    "Test picture attached",  <- so far I have not seen it in any photo so does not                                                 matter what it is.   I think ?
    ["/home/pi/photos/photo-" + timeString + ".jpg"] )   <- this is where the file is        to send it
    You can see from the web sites what I copies and what I didn't. With Facebook and Flickr having email uploading makes this work out great....
View all 5 instructions
Bobby Feather wrote 04/12/2016 at 21:34 point
It was my first time doing any thing like this. I did finish the project, Just have not updated the page yet with the info. It turned out to be very hard to get from place to place, and it takes up to much room in my living room to store it when I'm not using it. I saw a build that your phone could connect to I might try to . I might try to edit the code to print out the photos and still email or upload it to face book they really were not a great photos eather. The lighting was off a lot or it might make the photo real red or yellow....I have another project I'm working on if you would like to look at that one. I could use help with my code it 7 years old and its made with parts of old code so it has stuff that needs updated. I have only updated it to work with the newest arduino IDE....take a look
Ar wrote 05/03/2016 at 03:18 point
Hi! I didn't even get notified you replied, just saw your message =( There's the "Reply" button, it's super convenient because it's got notifications attached to it. Please do use it.
You could make it inflatable, I guess =) I could take a look at that code in my spare time. Reply to this with a link, or, better, send me a private message.
Ar wrote 04/12/2016 at 01:28 point
Hi! Just a friendly suggestion - you could put your Python code in a build log, and link to it from the instructions, since page feels cluttered and code is kinda hard to read with this approach =)
Generally, build instructions are to be short. Build logs, however, are meant to be long - and they do have much more features, such as code highlighting, which amazingly improves readability!
