Board Schematics
A project log for Power Supply B3603 Alternative Firmware
B3606 is a cheap MCU controlled power supply, I'm reverse engineering it and writing software to add serial port and more features.
baruch-evenBaruch Even 02/20/2015 at 12:490 Comments
Board schematics for the B3606 top and bottom boards were done by user flex on the EEVblog forum. This should help immensely with figuring how to drive all the components.
I've already managed to drive the CV/CC leds, partially successful with the 7-segment display. Still unsuccessful with the output enable part and the buttons.
I did manage to get the PWM sorted but without the output enable it doesn't help.
