Bottom frame progress
A project log for Cheap n' Nasty Cutting Machine
Yet Another CNC Machine
koswixkoswix 02/17/2015 at 21:140 Comments
Slight change in the design of the bottom frame - was offered some 25x25mm box section for free so decided to go with that. I'll weld two lengths together along the rail sides so that there's enough room to mount the sbr rails.
The lengths are all cut to size, just need to clean up the ends and weld it together tomorrow.
http://m.imgur.com/qGW5ddp
