Arduino ST4 telescope control
Telescope GOTO and autoguiding through ST-4 with an arduino
The purpose of this project is to connect a telescope to a computer through the mount guide port (ST-4 port) using an arduino in order to cheaply add GOTO and autoguiding capabilities.
The ST-4 Port is easy to add to "low cost" motorized mounts like the EQ4 or EQ5, and the operation requires minimal modification to your shiny mount.
Hardest part is the code (Arduino sketch ~120 lines and ASCOM driver ~2600 lines), but I already wrote it for you :-)
Basically, you need to build the USB-ST4 interface described in the github project page and modify your control pad like explained here if it doesn't have an ST4 port.
Modifying the control pad means soldering and wiring an RJ12 socket to the pad buttons.
Once the hardware is done, you will need to install the ASCOM platform and the driver.
After this you can use a software like the open source stellarium to play with your telescope or PHD for astrophotography.
More details are available on the github project page.
Here is a small guide to use it with stellarium.
Sample video of the telescope moving:
  • 1 × Arduino For interfacing with USB
  • 1 × TLP521-4 optocoupler In order to isolate the arduino from the autoguide port
  • 2 × RJ12 socket 1 if your mount already has an ST4 port
  • 1 × RJ12 straight cable To connect the adapter and the mount
  • 1 × A case for the adapter Excepted if you prefer to see the bare electronics :-)
View all 6 components
View project log
pparida wrote 04/21/2021 at 16:24 point
Thanks, Kevin for such a wonderful project. I recently converted my SkyView Pro mount to perform auto-guiding. Being a newbie, I am a little confused about the GOTO functionality.  I am using Stellarium along with Stellarium scope as suggested on your GitHub page. In Stellarium, I see the options to input the RA/Dec coordinates of the target and slew to it. However, how would Stellarium know what is the current position of the mount?  I would really appreciate any inputs on this.
Kevin Ferrare wrote 04/22/2021 at 20:21 point
Hi, I wrote a small doc explaining how to use it with Stellarium as their UI is a bit counter intuitive at first: https://docs.google.com/document/d/1PdI5651y0lIedtD94rbz3N_4thCQ0FP9VDVk0RaTFMk
I personally use Cartes du Ciel which has less eye candy but is easier to use and has more built in tools: https://www.ap-i.net/skychart/start?id=en/start
pparida wrote 04/23/2021 at 16:44 point
Thanks, Kevin. This is really useful. Also, I will give Cartes du Ciel a serious try.
weisz.samuel wrote 04/17/2021 at 11:21 point
Hey, this seems like a really cool project, so I wanted to make it for my Skywatcher Star Adventurer (2i). Unfortunately I was unable to find the TLP521-4 optocoupler, so I had to get the pc817 4 (on a green pcb) (the only one I could get in a reasonable amount of time). I didn't  think much about it, but after trying it out it didn't seem to work. Does anyone know if that optocoupler should be usable (or if it's just me doing something wrong). The optocoupler does get the signal from the arduino (LEDs on it blink), and I was able to see a change in resistance when it was enabled, but the Star Adventurer didn't get any signal (the LEDs weren't blinking). Is there a way to test if it might just be the mount's st4 port that is broken (like connecting the wires by hand maybe)? Thanks in advance, Sam
pparida wrote 04/21/2021 at 16:31 point
Hi Sam, I have used PC817 4 channel optocoupler successfully for the Orion Skyview pro mount. Unfortunately, I don't know how to troubleshoot your problem. Hope you resolve it soon.
weisz.samuel wrote 04/22/2021 at 11:43 point
Thank you very much for your response, it already helps me a lot. I'll just do more troubleshooting, but I think my ST-4 port might be broken.
ezio.zamboni wrote 01/22/2021 at 12:00 point
hello and congratulations on your great project
I built as your description, my problem is that at the exit of the TPL521 sending any command eg. RA- output Pin 5 Arduino 4,7 V at the input pin 1-2 TPL521 I have 1,2 V at the output Pin 16-15 0 V ??? this result does not seem normal to me
Thanks again for an answer
Kevin Ferrare wrote 03/01/2021 at 21:52 point
This is normal, the TLP is an optocoupler, it acts like a switch so when there is current flowing between pin 1-2, current can pass between 15-16 (closed switch), it's normal to read 0V here :)
fedevento wrote 01/16/2021 at 15:31 point
Hi @Kevin Ferrare , thanks for this wonderful project, i have a skywatcher star adventurer and was trying to use your trick to use a usb camera. I get the "ok" replies from the serial console but the leds in the mount dont flicker (which means no commands are arriving). Do you think that my problem is that im using PC845 instead of TLP521-4? what would happen if i go directly from the arduino to the rj12? Sorry about my ignorance! thanks for this great project!
Kevin Ferrare wrote 03/01/2021 at 21:49 point
I dont think that the PC845 is the issue, specs are similar to the TLP.
Plugging directly the arduino to the RJ12 would not work because ST4 works like button presses which are simulated by the optocoupler.
When you send a command, you can maybe check with an LED connected to the corresponding arduino pin, if it lights up then you can check with a multimeter if there is continuity between the corresponding outputs pins of the optocoupler.
If there is it means that the problem is with whatever you are connecting to. ST4 is not really a standard so pinout can be different depending on the maker.
weisz.samuel wrote 04/17/2021 at 14:42 point
Did you get it to work in the end?
vzr wrote 12/16/2020 at 17:41 point
When PHD2 send RA+# command, RA tracking speed remains adjusted only for 1 arduino clock cycle (and you reset your pins right away), which essentially does nothing noticable and increased pooling rate from PC can't help because your serial interface have default 1000ms timeout (adjust Serial.timeout() ?). Nothing in this project actually helps with autoguiding, it's almost completley unusable. Only thing that helps a bit is catch-22: Switching rate of your TLP521-4 (<100Hz) actually does all of the job, because it keeps "button pressed" for additional 10ms (accidentally?), but you run into async opcode from PHD2... Lot of thing need to be optimized in order to use this effectivelly and method for "pressing buttons" may or may not work, depending on remote controller vendor settings for this button pooling rate.
Kevin Ferrare wrote 03/01/2021 at 21:41 point
I am not sure I understand the problem. In the arduino code, the ST4 signal lasts as long as no other command is sent. In ASCOM, it lasts as long as specified by the software, seconds or minutes for GOTO and milliseconds to seconds for pulse guiding.
vzr wrote 12/15/2020 at 16:26 point
With Your permission I would like to use your ArduinoST4 ASCOM driver in my Sidereal Sky Tracker project. I assembled platform all by myself, without any proprietary products. Therefore I do not have remote or ST4 port. I implemented ST4 protocol directly via arduino serial interface and abstracted button events with firmware. This way, I am not tied up to 2x, 4x and 8x sidereal speed multiplers from controller, but much like anything, lets say 0.25x-2.00x (0x to 2x for RA, I only have RA axis)... Wish me luck :D
Serhii Solohub wrote 10/22/2020 at 00:29 point
Thnx, your schema helped me to figure out the troubles with ST-4 port for my controller :-) .
elfirmamento.astronomia wrote 09/04/2020 at 19:09 point
Hello my name is Walter, I am from Argentina. I have a 150x750eq3 with dual axis motorization.
I have built the layout that appears in this website and I am having the following problem:
Using the software both Cart du Ciel and Stellarium do not send a signal to the motors, but they do if I use ASCOM sending the commands. Thanks for your time.
Kevin Ferrare wrote 03/01/2021 at 22:00 point
Do you mean it works if you send commands directly to the arduino or via some other ASCOM software? If you check the "Debug Log" checkbox in the configuration, it outputs some logs in text files in the ASCOM log folder here: "My Documents\ASCOM"
You could check that the application is correctly initializing ASCOM.
aaron.ruhs wrote 05/09/2020 at 16:43 point
@Kevin Ferrare Hey, great project. I'm think about equipping my Star Adventurer with declination guiding (can only RA out of the box, no dec. motor avail.).
Where can I get information on the signal on the two dec. lines from the guider. Simple pulses on one or the other line for left or right ?
Varying pulse lengths? Or only varying pulse count ?
I would be so grateful if you tell me how it works or where I can find the specs.
Thank you in advance : )
Aaron
Kyle h wrote 08/09/2019 at 17:55 point
@Kevin Ferrare Question, were you able to get ride of your control box for the EQ motors? Or did you jsut add this into it so that it controls your EQ from computer
Conrad12n wrote 12/15/2018 at 20:53 point
I am trying to implement this on a Losmondy G11 mount. Single axis drive on either axis works fine, however when I try to get RA and Dec simultaneously the mount does strange things, basically one or both axis stop working. At first I thought I was input power limited but I boosted the available current and keep getting same result.
My implementation has LED's on the input to the opto-isolator (very helpful for diagnostics) so I know the signal is getting thru the Arduino. Also I see the resistance on the output side of the coupler dropping when I command the axis ( single or dual axis)
I have seen some comments suggesting the G11 mount (non Gemini, 492 DDS, quite old pre 2000) only works with a single axis driven at a time.
Questions:
1) has anyone seen similar results?
2) Is there any modification that drives the axis serially, completing one move before starting the other?
In measuring the rpm of the axis motors I find they are turning 10-15 % slower than they should (AT 16 X speed) This may be compensated by adjusting the stated rates in the input.
Kevin Ferrare wrote 01/07/2019 at 22:33 point
Hi @Conrad12n
I had the issue with almost dead batteries, but it seems that in your case this is a limitation of the mount rather than an easily fixable issue.
If you feel like it, modifying the code so that both axis are not active at the same time is actually quite simple:
https://github.com/kevinferrare/arduino-st4/blob/master/ASCOMDriver/ArduinoST4Driver/ArduinoST4Driver/AxisController.cs#L169
Remove the if (async) and only keep what is inside the else. This way, each axis command will wait until completion.
I would add this as an option in the next version of the driver which is pending proper testing before release ...
Regarding the speed rates, you can adjust them in the dialog to match the actual measured speeds
stevemcclure wrote 08/30/2018 at 16:30 point
This looks like an amazing project and right up my street, so pleased to find something like this and credit to you for sharing this.
I have ordered all the electrical components plus a breakout board and hope to put everything in a small project box.
Regarding the arduino code, when verifying it I get an error of “resetpins was not declared in this scope” I imagine this is me not doing something right, but any help would be greatly appreciated.
Kevin Ferrare wrote 09/01/2018 at 23:21 point
Thanks for reporting the issue, apparently the ino file needed an update to compile with arduino 1.8 (it was initially developed with 1.6 and I never installed newer versions on my computer).
I fixed it and pushed it:
https://github.com/kevinferrare/arduino-st4/releases/download/1.0/ArduinoCode.ino
h.movahedi.m wrote 08/16/2018 at 13:24 point
Thanks sir.
This is very useful for me in my autoguider project.
n3upy.sn wrote 03/19/2018 at 19:16 point
Any idea if this would work with a Bushnell Northstar to track low earth orbit sats?
Kevin Ferrare wrote 07/31/2018 at 16:32 point
I don't think so, the objects will probably move too fast for the mount.
licvinka59 wrote 02/01/2018 at 17:46 point
Thank you for the ST4 driver, Kevin. Found this thing almost two years ago. Everything worked out. There are PHD and GOTO. Could not resist not thanking. )
Kevin Ferrare wrote 02/05/2018 at 16:12 point
Thanks for the kind message!
Alexander Axglimt wrote 10/10/2017 at 13:35 point
Hello!
I have been using your arduino telescope control hack with success for a year! Mainly used the GoTo function. Even though it it way off when slewing, since i'm using plate solving it does not matter, just slew again and platesolv until the target is centered, and luckily APT does this automatically, so it is still much faster than trying to find invisible dso's manually :D
However, the issue that DEC is reversed after meridian flip and that the goto's are way off, is a little frustrating... Now i read in the comments that you have release a beta version that takes care of meridian flip! :D , so i will download that and test...
Regarding slewing... since mount has 16x i guess i will have to play with the Axis sideral rates in the driver? Would it work to tweak these numbers until the slews are better?
Kevin Ferrare wrote 10/10/2017 at 14:08 point
Hi Alexander,
Poorly tested next version with meridian flip is here:
https://drive.google.com/file/d/0B04IJvbw0nqmMUJVX25MQ2NJNFU/view
I wish I had time to take my telescope outside to properly test it and release it. Last time I could do this, the battery was dying and slews were not accurate at all so I couldn't validate the build and release it.
If you use 16x, you need to properly configure it in the driver, else it will be way off indeed :-)
With the new version, the +1/-1 you need to apply on right ascension is automatically done by default
Please tell me if you make it work as intended or if the result is not as expected!
Regards,
Kevin
Alexander Axglimt wrote 10/11/2017 at 05:42 point
Sure! Unfortunately i've had bad weather here for a long time... i hope it will clear up soon so i can test.
One question, how does the driver know that you are on the other side of the meridian? Is there position feed-back from the software (APT) to the driver?
Kevin Ferrare wrote 10/11/2017 at 07:24 point
The beta version of the driver has a checkbox to tell whether it is meridian flipped or not. This is a parameter that is setup at connection time though.
Alexander Axglimt wrote 10/11/2017 at 08:36 point
Ok, so it should work to disconnect the scope in APT, tick the checkbox  and re-connect it in APT?
Kevin Ferrare wrote 10/11/2017 at 08:42 point
Exactly, for now you need to reconnect.
Alexander Axglimt wrote 10/11/2017 at 08:47 point
Sweet! Now i don't have to manually throw a switch on the hand controller anymore!
Have you any plans to bypass the hand controller altogether and drive the motors directly? That would allow for higher slew speeds, different tracking speeds, etc.. right?
Kevin Ferrare wrote 10/11/2017 at 08:56 point
Bypassing the controller would improve performance a lot indeed, however there is already a project for this: https://www.astroeq.co.uk/
Alexander Axglimt wrote 10/11/2017 at 10:39 point
Hmm, yeah but that one requires programmed pic's... I think you could do it better and simpler! I have faith in you! :D
Kevin Ferrare wrote 10/11/2017 at 11:42 point
Thanks ! However there is already an arduino version of it for those feeling lazy :D
https://www.astroeq.co.uk/tutorials.php?link=/doku/doku.php?id=buildown
stephan_bock wrote 10/07/2017 at 06:52 point
Hi Kevin,
I recently found your project and I decided to go ahead and make my EQ5 into a GoTo mount. It worked fine, thanks to your detailed description.
Nevertheless, I modified the solution slightly. Instead of using pins 2,3,4,5 I used 2,4,6,8. Why? Because it made a much nicer layout on the stripboard with the optocoupler next to the Arduino. If you like, I can post a quick picture of the finished product.
Next is autoguiding - a quick test with PHD2 already showed potential...
Thanks again for the inspiration and writing the driver code.
Stephan
Kevin Ferrare wrote 10/10/2017 at 13:56 point
Hi Stephan,
Thanks for your comment!
Indeed, it makes more sense to have only one every 2 pins connected to the optocoupler since it leaves space for the ground.
If I recall, I think I did like you in the version I use with the optocoupler on a PCB.
Regards,
Kevin
subscriptions wrote 08/14/2017 at 16:19 point
Hi Kevin, One of the things I want to do is really remote control.  I now have Arduino powered goto and guiding (coutesy of you), Arduno-powered remote focusing (but not yet full HFW-stle algorithms), Arduino-powered camera release and remote USB camera control.
But I can't turn it all off remotely.  It struck me that if we had some sort of toggle switch, like the optocoupler, that stayed on or off, even if the Arduino rebooted, it could be used to control the power cable to the remote handset.
What sort of electronic component would work like this?  A sort of semi-permanent, toggle relay.
Regards
Steve.
Kevin Ferrare wrote 08/15/2017 at 11:45 point
Hi Steve,
It seems like you built quite an impressive setup! I would be very interested in seing some pictures :)
I would love remote control as well, to get rid of all the cables waiting for you to trip over in the dark night.
One year ago I started to experiment with bluetooth connection (HC-05 bluetooth to serial), and I got it working, but I never completed the project, mainly due to a lack of time. I wanted to put all the electronics including the battery into a single box attached to the mount.
Regarding the component you are looking for, as far as I understand, a latching relay would do the job.
Regards,
Kevin
subscriptions wrote 07/11/2017 at 15:50 point
Hi Kevin.
To continue the saga, I now have guiding, focusing and remote exposure all working on the Arduino.  I'm planning to implement fan control in the same way, and maybe even weather.  I was also trying to use it to do limited star-hopping eg Vega to M57, because otherwise I find some of these Deep Sky Objects difficult to locate, however, it always seemed to send me off to the other side of the galaxy and I couldn't work it out until I realised that my meridian flips were reversing all my Dec commands.
Have you come across this, and what have you done about it?
Regards,
Steve.
Kevin Ferrare wrote 07/11/2017 at 16:27 point
Hi Steve,
I was preparing a version with meridian flip taken in account in the ASCOM driver for GOTO.
It is unreleased and not well tested due to lack of time, if you want to give it a try, it is here:
https://drive.google.com/open?id=0B04IJvbw0nqmYWh6aVZwcXlNUzQ
Regards,
Kevin
subscriptions wrote 07/11/2017 at 16:41 point
Thank you for this, and for your quick response.  Sadly, I don't use Ascom, I'm Linux.  Do you just reverse the Dec pins?  Is that all there is to it?
Presumably you don't need to reverse the pins for guiding, since the guide camera is also reversed.
Kevin Ferrare wrote 07/11/2017 at 18:28 point
Basically yes, the driver inverts the commands it is giving to the mount for DEC.
For guiding, I don't see why you would have to do anything indeed, excepted in cases where you would like to recalibrate drift rates if this is ever useful.
I never tried guiding with meridian flip so I may not be correct ...
subscriptions wrote 07/12/2017 at 05:54 point
Yes, that is what I understand too.  I was testing at the weekend and everything pretty much worked except for the GOTO.  In fixing the GOTO, I don't want to break the guiding.
Kevin Ferrare wrote 07/12/2017 at 07:06 point
Well if you want to use both GOTO and autoguiding, there is an option in the unreleased driver to do the meridian flip so that the calculation for GOTO movements takes in account the inversion of DEC axis. There is also an option in PHD to revert the controls (to cancel the driver inversion for guiding).
Did you get a working goto under linux?
subscriptions wrote 07/12/2017 at 07:33 point
Yes, my GOTO works, but only for small distances, since the slew rate is only 16x.  I tend to star-hop within a constellation, or two local constellations, otherwise it's quicker to go outside and move it manually.  I just wrote a python program to send your DEC# and RA# to the serial port and it all works beautifully.
And my calculations are not correct yet, because of the Meridian flip.
I've updated the calculation and next time I get a clear night I'll check it.
I have created two "hubs" to append to the Arduino.  So the Arduino is in one box on a small table under the mount together with the "Mount Hub", a powered USB hub and the drive handset, while the "OTA hub" is on the focuser connected with a VGA cable (15 cores).  That means I only need one cable running up the tripod.  Actually, all my focusing, exposure and dew controllers in the OTA hub are much more successful than the DEC/RA controls on the Mount Hub!  Which is a bit sad. However, I keep on going.
sudhangshughose wrote 07/08/2017 at 14:14 point
Hi Kevin,
First of all thanks a lot for this nice project. I have followed your project meticulously. I could able to control the eq3-2 mount. I have one silly question. How the system (stellarium) could understand the starting position of the scope to use goto feature. (In my case at starting the scope marker on stellarium starts well below from horizon. I live in Northern hemisphere approx 13 degrre N). Apology in advance if i sound silly.
Kevin Ferrare wrote 07/11/2017 at 16:23 point
Hi,
GOTO works like this:
 - You manually point the telescope to a known star
 - You tell stellarium that it is pointed to this star (SYNC operation)
 - Then you select the destination in stellarium and press SLEW
