Pro-Mini CLone
I bought a Pro-Mini clone because I wanted low power (3.3v 8MHz) and a nice bolt-on PCB:
This board uses a USB-FTDI adapter. As want to use the E-Paper display and rationalise the wiring, I modified epdif.h and epdif.ccp to repurpose MISO (as it is unused):
- BUSY D8 (INPUT)
- RST D12 (OUTPUT) (was MISO)
- DC D9 (OUTPUT)
- CS D10 (OUTPUT)
- DIN D11 (MOSI)
- CLK D13 (SCLK)
To do this I moved the pinMode definitions (in epdif.cpp) to after:
- SPI.begin();
and remapped the #defines in epdif.h to:
- #define BUSY_PIN 8
- #define RST_PIN 12
Although the E-Paper module sees 4.75 volts while the USB-FTDI adapter is connected, in normal operation it will see 3.3 volts. It is a shame the FDTI voltage out is 5v even with the 3.3v switch selection. Checking the WaveShare website this seems to be okay short term. Here is my hookup:
So I have D0-7 and A0-7 free and all ready for low-power battery operation.
Magic
