Be careful
A project log for Wireless Thermometer with using only a HC-12
simple solution which doesn't require any additional hardware
vladlenvladlen 11/29/2018 at 10:300 Comments
Note that you frequently might meet a trouble with tuning it because the crystals on different samples are different from each other if they were bought from the different sellers!
It was discussed earlier. link
