EEPROM writer for AT28C256 using Arduino Mega
Quick and dirty breadboard circuit and Arduino sketch to make possible write in the AT28C256 EEPROM
When making my pet project JACA homebrew Computer I quickly realize that I would need some way to write in the ROM chips (for microcode and for the programs itself). Obviously I could buy an EEPROM writer but I prefer to have some fun doing my own. Besides this I was learning Arduino and it looks like a great way to acomplish this. (For this same reason pardon me if there is some shame bad programming technique.
Source code:
https://create.arduino.cc/editor/albs_br/94b6f3f5-413d-4714-80dc-836bf5b3705c/preview
mitchgollub wrote 10/22/2020 at 12:37 point
Has anyone gotten this to work?  I hooked up my Mega to match the sketch and the picture, but I'm still unable to write to the memory of my AT28C256 chip.
jamesaharrisonuk wrote 12/27/2019 at 05:34 point
Do you have a schematic? I've guestimated wire up by looking at the pictures, but its not working. The Sketch code uses 16 (0-15) address lines, but the AT28C256 only has 15 (A0-A14 and there is no A15). Where does the extra address line hook up to. Ive changed the sketch to ADDRESS_BUS_SIZE variable to 14.
Marcel van Kervinck wrote 04/02/2018 at 10:37 point
I made one like this as well, it is a great tool for learning these chips. After a while I rebased the code on MEEPROMMER. You have to play around with the cycle times and retry-scheme to speed-up things. The code can get tricky from there. Still it is worth looking at it. https://github.com/mkeller0815/MEEPROMMER
When I got to the point of locking/unlocking ATmel EEPROMs I found some issues with that. I debugged them (there is a problem in MEEPROMMER). I got it to work, but I had a "proper" programmer shipped from China as well and never looked back. They are so much faster, easy to use, and quite cheap.
I just saw "The 8-bit Guy" just unbox exactly the programmer I'm using!
Dylan Brophy wrote 03/10/2018 at 07:04 point
I did something like this before! Pain to do, and I only got it working once :P  Cool to see this on HaD
