BeagleLogic Cape Design Files
A project log for BeagleLogic
Turns your BeagleBone Black/Green into a 14-channel 100Msps Logic Analyzer
kumar-abhishekKumar, Abhishek 09/20/2015 at 20:450 Comments
This Project Log references the rule of the 2015 Best Product Finals in which participants are required to post Gerber and Drill files of their builds.
The BeagleLogic design files are located here on the project GitHub repository:
https://github.com/abhishek-kakkar/BeagleLogic/tree/master/cape
For the gerbers and PDF copy of the schematics and board layouts, this is the Google Drive Folder:
BeagleLogic Cape Fabrication Outputs (Generated on 21st September)
The KiCAD design files are always the latest design while the fabrication outputs are of the last hardware release. They will be updated when a new revision is released.
