New Improvement
A project log for TwinTeeth: The PCB mini-factory
Diyouware TwinTeeth is a open-source PCB mini-factory targeted to the electronic hobbyists.
diyouwareDiyouware 09/19/2015 at 13:050 Comments
We published a lead-screw improvement to the original design. We decided to reduce the size of the acme screws to reduce possible wobble and we also designed a new lead-screw top support which will hold the bearing and a bolt to adjust the motor coupler flexibility.
You can see the new design here:
http://www.diyouware.com/node/193
