PCB Routing
A project log for (Yet another) BeagleBone Display+CapTouch cape
A cape for the BeagleBone Black using readily available replacement spare TFT Panels and capacitive touchscreen originally used in tablets
kumar-abhishekKumar, Abhishek 02/24/2015 at 02:490 Comments
Just finished routing the PCB:
At the bottom there's the 50 pin FPC connector for the panel. The placement for the LCD data bus was a bit weird, and I had to use a lot of vias there.
