June 2016 Progress report
A project log for Speeduino
The Arduino ECU / EMS Project. Open, cheap, hacker friendly engine management
Josh StewartJosh Stewart 07/01/2016 at 08:290 Comments
<Insert usual spiel about me not being able to believe it's the end of June already>
OK, short, sweet and to the point on the update this month. So much good stuff happening, but at least for June the firmware is a little quiet on the new features front. That's not to say it hasn't got a lot in it though!
On the juice side of things, a lot of work has been done on the Flex fuel capability. Whilst it's not fully ready for June, the ability to read, display and log a flex sensor has been added. classified has done a heap of work on the actual fuel/ignition adjustments side of things and I'm hoping this should be merged within July sometime.
A LOT of work has gone into squashing bugs that were identified, some small, some more significant. I'm happy to say that from a reliability point of view, this release is the best to date by a long margin so I recommend upgrading for this alone.
Rather than drag it out, here's a full summary listing of the changes:
On the whole this is a solid update, if even its not feature rich. I highly recommend it for all users for general stability etc.
As usual, the release is available on the wiki: http://speeduino.com/wiki/images/3/36/Speeduino_Jun16.zip
I have also begun tagging releases on github to allow easier tracking through there.
