Vase Dazzler Features
This project uses addressable color LEDs to light up 3D printed a vase of your choice. It includes a compact housing that the vase sits on top of. In the back of the housing are controls: a dial to set brightness and a pushbutton to select one of ten pre-programmed color patterns. Color patterns include fades between colors, blinks, and even a "candle flame" effect.
Here's a video with one of the modes:
Open Source License
This project is open source (Creative Commons Attribution-ShareAlike 4.0 International) and all source files, STL files, source 3D models, etc. are posted publicly for your hacking pleasure.
Parts List
The electronics parts are all non-proprietary and commonly available. You are free to source the parts yourself but if you'd like to help support our future projects please consider purchasing a complete kit from the Vorpal Robotics Store.  The kit at the store requires no soldering, making this a very fast and convenient build.
Parts:
Convenient kits that include all of the above parts, with all soldering completed for you, are available from the Vorpal Robotics Store. This project is open source, however, so feel free to source your own parts.
Electronics parts (shown soldered as they would be from the Vorpal Store Kit)
3D Printing Materials:
Tools needed:
File Repositories
Complete instructions
Complete instructions are posted on the Vorpal Robotics Wiki
Here are a few photos illustrating the basic ideas behind the build.
The flower stem leaves can be made to come down at a natural angle by heating them. Keep the flame moving! Don't let it catch fire. Have a bowl of water ready
Insert the pushbutton from the front:
Insert the potentiometer fromm the inside, bend the wires as shown so the nano will have room:
All the electronics are assembled and pot/button/LED Ring are inserted in base:
The nano kind of wedges in around the pot wires. You may need to wiggle it a little bit. Note the USB port for the nano faces out a hole in the back, this allows you to power the project using a USB cord and cheap mobile phone charger or computer USB port.
Here all the wires are routed and tucked into place, ready to put the top on and secure with a single screw in the middle:
Back view of the Vase Dazzler showing controls:
Front view of the Dazzler with purple-ish colored light effect:
The battery drawer on the bottom makes it easy to change batteries:
