Hackaday.io Hackaday.io
Sign up Log in
UV Glow Clock - it spins!
I wanted to build an unusual clock, and i had some UV Led's and glow in the dark filament on hand so here we are.
chris-mitchellChris Mitchell
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
45 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
591
0
45
4
Team (1)
  • chris-mitchellChris Mitchell
Join this project's team
  • source & schematic
  • Youtube vid
completed project
hardware
clock ultraviolet ds1307 28ByJ-48
This project is submitted for
  • Hackaday.com Tip Line
This project was created on 01/30/2018 and last updated 7 years ago.
Description
The glow disk is printed using glow in the dark (uv) PLA plastic
Other parts used...
Arduino Nano (v3)
10x UV LED's (5mm)
1x 28BYJ-48 Motor (cheap stepper motor)
1x DS1307 RTC clock module
Also used was some Black PLA for the base and some M3 nuts and bolts to mount the motor.
See it in action: https://youtu.be/Hr38LNuddBs
Code & schematic is on my github: https://github.com/boy1dr/UV_LED_CLOCK
3D Files on thingiverse: https://www.thingiverse.com/thing:2775280
Project Logs
Collapse
  • Created a build log
    Chris Mitchell • 02/05/2018 at 01:05 • 0 comments
    http://www.instructables.com/id/UV-Glow-Clock-It-Spins/
View project log
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
3D printed desk clock with large exposed gears
Project Owner Contributor
Desk Clock
steveSteve
A super sized 7 Segment Clock based on LED Stripes and Arduino.
Super Sized 7 Segment LED Clock.
mario-lukasMario Lukas
My Glow-In-The-Dark Plot clock uses an Arduino Uno, two 9g servo motors, a UV Led and a phosphorescent material to “draw” the time
UV Glow-In-The-Dark Plot Clock
tuckershannonTuckerShannon
A clock made from an old hard drive.
HDD Clock
bjorn-bosellBjorn Bosell
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "UV Glow Clock - it spins!", please tell us the reason.
Send message
Remove Member
