Ready for the VCF East, April 17-19
A project log for PiDP-8/I
Remaking the PDP-8/I using the Pi, simh & a replica front panel
oscarvOscarv 04/10/2015 at 23:420 Comments
Well, there they are, the four prototypes:
I played around a bit with connectivity options. So two PiDPs use a Raspberry Pi Model A+, the other two a Model B+. The machine in front has a slot on top to access the HDMI monitor connector (slot not necessary with the right HDMI cable, BTW), the other machines only run terminals from serial or network terminals which is all you need.
My better half has decided that our suitcases will be filled with more important things than PiDPs on the way back home from VCF East. Like shoes, I presume. So if you're at the VCF and want to take one of these PiDPs, please let me know :) They are 100% compatible with the future final version of the board, they just have some manual fixes on the PCB.
