Solar Powered USB Charger
A solar powered USB charger specifically for mounting on a bicycle.
A solar powered USB charger that I mounted on my bike to keep a old smartphone charged for music.
The plans for this project were larger, initially, but downgraded as I moved through to completion. I was looking to use this system this to power and control my bike's head and tail lights, a Raspberry Pi or music device, and speakers. I decided against that due to the number of wires that I would have to run all over my bike and the weight. As the system is shown, it already adds weight, I'm guessing below 5 lbs, but haven't weighed it.
I left plenty of space on the board so if I decide to add more to it in the future, I can.
I have taken the system with me on a 100 mile bike ride and it kept my phone running at 5% battery while playing music with the screen off, on a cloudy day. It did rain a bit during this time and I used a zip lock bag to cover the top, but had no issues otherwise.
If there are any questions please leave them in the comments and I will check on a monthly basis.
  • 2 × Medium 6V 2W Solar panel - 2.0 Watt https://www.adafruit.com/product/200
  • 2 × USB / DC / Solar Lithium Ion/Polymer charger - v2 https://www.adafruit.com/product/390
  • 2 × Lithium Ion Battery Pack - 3.7V 4400mAh https://www.adafruit.com/product/354
  • 1 × Mini DC/DC Step-Down (Buck) Converter - 5V @ 1A output - TSR12450 https://www.adafruit.com/product/1065
  • 1 × USB DIY Connector Shell - Type A Socket https://www.adafruit.com/products/1388
View all 13 components
  • 1
    Step 1
    Connect everything up and verify everything works on a breadboard to power a Raspberry Pi.
    Image from <http://www.polyideas.com/blog/2013/7/10/solar-powered-raspberry-pi>;
  • 2
    Step 2
    Make a cardboard template of the mounting plate, adjusting it so it will fit into the bag.
  • 3
    Step 3
    Layout the components on the cardboard template so they will fit.
View all 12 instructions
