mechanical speed reduction
A project log for Open Ground Penetrating Radar
Make the invisible visible for about $500.
glenn-powersGlenn Powers 07/31/2015 at 23:500 Comments
"choosing the best [mechanical] reduction ratio is the single most important factor in determining how well the motor will work in a particular application."
"Do not rely on electronic speed reduction to do the job of a mechanical speed reducer."
AmpFlow whitepaper:
http://www.ampflow.com/Using mechanical speed reduction.doc
