First Build
A project log for Motion Controlled Cabinet Light
An LED strip of white LEDs that can be turned on, dimmed, and turned off with a wave of your hand
Thomas SnowThomas Snow 03/14/2015 at 12:050 Comments
I built up the first board and did some tests. All seems to be as planned. I now need to drill out the holes in the project box and enclose everything. I have the LED Track cut and drilled, ready to install. The LED strips have been cut and joined (they are going to be installed in a corner cabinet area).
