Snags and blips
A project log for LED Display for Art purpose
An ongoing and constantly changing project. I aim to use an led grid system to display light in an artistic matter.
PristavePristave 07/28/2015 at 02:150 Comments
Snags I have encountered during the project and how I dealt with them
voltage drop once grid reached a certain point, - I remedied this by swapping out multiple adapters with a single 10A 5v Supply.
Bad LEDS - LOTS LOTS LOTS of testing with a multi meter!
Flexibility and stability between modules- by designing the modules around the LEDs themselves, the LEDs remained stable in a small circular cradle that was build in the 3d print. so the wires had slack but the flexible tubing that kept the grid together remained taut.
