GoSlo Code for Adafruit Trinket
A project log for GoSlo, A 3DPrinted Remote Pinhole Camera.
In which our hero adds a servo-driven shutter to his 3D printed pinhole cameras, & remote and programmable control via Arduino and friends.
theschlemtheschlem 03/06/2015 at 07:521 Comment
         RoboShutta
   Version 1
   For Arduino Trinket by Adafruit
Code for controlling a servo-driven shutter on a pinhole camera via a cable
from a distance.  Simplicity and reliability are paramount.  Such a remote /
automatically controlled shutter-equiped camers, mounted on GoPro (or similar)
hardware shall be collectively termed a GoSlo camera system.
Lacking proper PWM output, a clever hack is utilized to update the
position of the servo arm via an interupt.  This should have minimal
impact on functionality, but similar code could be easily written
for other Arduino (semi-) ompatibles.
Suitable camera applications are:
		http://www.thingiverse.com/thing:577223
		http://www.thingiverse.com/thing:495230
Servo-ready parts for these cameras are pending on Thingiverse.com
    created  02/21/2015
   by Todd Schlemmer theschlem@gmail.com
   SOURCES:
   Adapted from TrinketKnob/SoftServo by Adafruit
   RESOURCES:
      https://learn.adafruit.com/downloads/pdf/introducing-trinket.pdf
      https://learn.adafruit.com/trinket-gemma-servo-control/overview
      http://www.akeric.com/blog/?tag=arduino
This sketch allows for remote control of a servo-driven pinhole camera shutter.
    Required library is the Adafruit_SoftServo library
    available at https://github.com/adafruit/Adafruit_SoftServo
    The standard Arduino IDE servo library will not work with 8 bit
    AVR microcontrollers like Trinket and Gemma due to differences
    in available timer hardware and programming. We simply refresh
    by piggy-backing on the timer0 millis() counter
    All circuitry is housed in a case with the 6-12V battery pack, and connected to the
    shutter servo via a standard 3-wire servo cable(s).  Servos can be controlled by
    connecting mutiple cables, many meters in length.
    Handheld remote
      power switch
      safety switch -momentary (unable to open shutter if not depressed)
      shutter switch -toggle
      status LED tied to PIN1, used for status, debugging, error purposes
 CIRCUITRY:
******** diagrams and pinouts ***********************
                         Trinket Arduino Compatible
                                By Adafruit
                                MINI USB
                                ________
                          _____|        |_____
                         |  _  | ||  || |  _  |
                         | (_) | ||  || | (_) |
                         |  _  | ====== |  _  |
            Green LED    | [G] |________| [R] |   red status LED
            (power)      |                    |
                  BAT +  | O  [] [] []  ||  O |   USB 5V+
                  GND -  | O   =[]=  []     O |   #0               SERVOPIN
                  #4     | O                O |   #1  (red LED)    LEDPIN
                         |     _u_u_u_        |
   SAFETYPIN      #3     | O  |       |     O |   #2               SHUTTAPIN
                  RESET  | O  |_______|     O |   5 V+ (regulated from BAT)
                         |  _   n n n      _  |
                         | (_)  |    |    (_) |
                         |_     |_[]_|   _____|
                           \____________/
                             Reset switch
               Servo Plug
                _______________
               |   __  _       |
    Ground     |  [__] _]      |==brown wire============
               |   __  _       |
    5V +       |  [__] _]      |==orange wire===========
               |   __  _       |
    Signal     |  [__] _]      |==yellow wire===========
               |_______________|
 ******** ARDUINO Wiring ***************************************
BAT & GND wired to battery pack through power switch
Pin #0 to servo signal
Pin #1 to status LED
Pin #2 from shutta switch (toggle 1=open 0=closed)
Pin #3 from safety switch (momentary)
// ***************** Declarations and Initializations *******************
   //int VariableName = 2;       //comment
   //#include <Library.h>        // some library module
#include <Adafruit_SoftServo.h>  // SoftwareServo (works on non PWM pins)
#define SERVO1PIN 0   // Servo control line (orange) on Trinket Pin #0
#define LEDPIN 1      // Status LED wired to Pin #1
#define SHUTTAPIN 2   // Toggle switch (shutter control) on Trinket Pin #2 (Analog 1)
#define SAFETYPIN 3   // Momentary pushbutton on Trinket Pin #3
Adafruit_SoftServo myServo1, myServo2;  //create TWO servo objects
int OpenedValue = 102;      // Servo position for opened shutter, determined experimentally with ShuttaSetup
int ClosedValue = 23;       // Servo position for closed shutter, determined experimentally with ShuttaSetup
int servoPos;               // variable for servo position
void setup()
  // Set up the interrupt that will refresh the servo for us automagically
  OCR0A = 0xAF;            // any number is OK
  TIMSK |= _BV(OCIE0A);    // Turn on the compare interrupt (below!)
  pinMode(LEDPIN, OUTPUT);
  pinMode(SHUTTAPIN,INPUT);
  myServo1.attach(SERVO1PIN);     // Attach the servo to pin 0 on Trinket
    CloseShutta();
    digitalWrite(LEDPIN, HIGH);
    delay(1000);
    digitalWrite(LEDPIN, LOW);
void loop()
      Start:  // label used to break out of routine if necessary
        if (digitalRead(SHUTTAPIN))
              OpenShutta();
            else
              CloseShutta();
// We'll take advantage of the built in millis() timer that goes off
// to keep track of time, and refresh the servo every 20 milliseconds
// The SIGNAL(TIMER0_COMPA_vect) function is the interrupt that will be
// Called by the microcontroller every 2 milliseconds
    volatile uint8_t counter = 0;
          // this gets called every 2 milliseconds
           counter += 1;
          // every 20 milliseconds, refresh the servos!
            if (counter >= 5)
                     counter = 0;
                     myServo1.refresh();
// subroutine  OpenShutta *******************************
void OpenShutta()
          servoPos = OpenedValue;
          myServo1.write(servoPos);               // tell servo to go to position
          delay(200);                            // waits 1500ms for the servo to reach the position
// subroutine  CloseShutta *******************************
void CloseShutta()
          servoPos = ClosedValue;
/* subroutine LEDdebug *******************************
      Used to demonstrate some small value for debugging purposes
      by flashing Pin1 LED some number of times.
    void LEDdebug(int number)
         for (int i=1; i <= number; i++)
          delay(500);
          delay(500);
theschlem wrote 03/06/2015 at 07:54 point
The formatting is slightly crowded, but you should be able to cut and paste into the Arduino IDE and preserve formatting.
