Photos, or it didn't happen!
01/31/2018 at 18:43 • 0 commentsHey
Here's a link to some pinhole photos I have made with the GoSlo 6x9:
https://www.flickr.com/photos/theschlem/albums/72157650566878617
Photos
03/06/2015 at 08:15 • 0 commentsAt this writing, the first two rolls of film have been uploaded to Flickr.
Also a blog post to the 52Rolls photo project has been uploaded.
GoSlo Code for Adafruit Trinket
03/06/2015 at 07:52 • 1 comment/* RoboShutta Version 1 For Arduino Trinket by Adafruit Code for controlling a servo-driven shutter on a pinhole camera via a cable from a distance. Simplicity and reliability are paramount. Such a remote / automatically controlled shutter-equiped camers, mounted on GoPro (or similar) hardware shall be collectively termed a GoSlo camera system. Lacking proper PWM output, a clever hack is utilized to update the position of the servo arm via an interupt. This should have minimal impact on functionality, but similar code could be easily written for other Arduino (semi-) ompatibles. Suitable camera applications are: http://www.thingiverse.com/thing:577223 http://www.thingiverse.com/thing:495230 Servo-ready parts for these cameras are pending on Thingiverse.com created 02/21/2015 by Todd Schlemmer theschlem@gmail.com SOURCES: Adapted from TrinketKnob/SoftServo by Adafruit RESOURCES: https://learn.adafruit.com/downloads/pdf/introducing-trinket.pdf https://learn.adafruit.com/trinket-gemma-servo-control/overview http://www.akeric.com/blog/?tag=arduino This sketch allows for remote control of a servo-driven pinhole camera shutter. Required library is the Adafruit_SoftServo library available at https://github.com/adafruit/Adafruit_SoftServo The standard Arduino IDE servo library will not work with 8 bit AVR microcontrollers like Trinket and Gemma due to differences in available timer hardware and programming. We simply refresh by piggy-backing on the timer0 millis() counter All circuitry is housed in a case with the 6-12V battery pack, and connected to the shutter servo via a standard 3-wire servo cable(s). Servos can be controlled by connecting mutiple cables, many meters in length. Handheld remote power switch safety switch -momentary (unable to open shutter if not depressed) shutter switch -toggle status LED tied to PIN1, used for status, debugging, error purposes CIRCUITRY: ******** diagrams and pinouts *********************** Trinket Arduino Compatible By Adafruit MINI USB ________ _____| |_____ | _ | || || | _ | | (_) | || || | (_) | | _ | ====== | _ | Green LED | [G] |________| [R] | red status LED (power) | | BAT + | O [] [] [] || O | USB 5V+ | || | GND - | O =[]= [] O | #0 SERVOPIN | =[]= | #4 | O O | #1 (red LED) LEDPIN | _u_u_u_ | SAFETYPIN #3 | O | | O | #2 SHUTTAPIN | | | | RESET | O |_______| O | 5 V+ (regulated from BAT) | _ n n n _ | | (_) | | (_) | |_ |_[]_| _____| \____________/ Reset switch Servo Plug _______________ | __ _ | Ground | [__] _] |==brown wire============ | __ _ | 5V + | [__] _] |==orange wire=========== | __ _ | Signal | [__] _] |==yellow wire=========== |_______________| ******** ARDUINO Wiring *************************************** BAT & GND wired to battery pack through power switch Pin #0 to servo signal Pin #1 to status LED Pin #2 from shutta switch (toggle 1=open 0=closed) Pin #3 from safety switch (momentary) */ // ***************** Declarations and Initializations ******************* //int VariableName = 2; //comment //#include <Library.h> // some library module #include <Adafruit_SoftServo.h> // SoftwareServo (works on non PWM pins) #define SERVO1PIN 0 // Servo control line (orange) on Trinket Pin #0 #define LEDPIN 1 // Status LED wired to Pin #1 #define SHUTTAPIN 2 // Toggle switch (shutter control) on Trinket Pin #2 (Analog 1) #define SAFETYPIN 3 // Momentary pushbutton on Trinket Pin #3 Adafruit_SoftServo myServo1, myServo2; //create TWO servo objects int OpenedValue = 102; // Servo position for opened shutter, determined experimentally with ShuttaSetup int ClosedValue = 23; // Servo position for closed shutter, determined experimentally with ShuttaSetup int servoPos; // variable for servo position // ************************************************** void setup() { // Set up the interrupt that will refresh the servo for us automagically OCR0A = 0xAF; // any number is OK TIMSK |= _BV(OCIE0A); // Turn on the compare interrupt (below!) pinMode(LEDPIN, OUTPUT); pinMode(SHUTTAPIN,INPUT); myServo1.attach(SERVO1PIN); // Attach the servo to pin 0 on Trinket CloseShutta(); digitalWrite(LEDPIN, HIGH); delay(1000); digitalWrite(LEDPIN, LOW); } // ************************************************** void loop() { Start: // label used to break out of routine if necessary if (digitalRead(SHUTTAPIN)) { OpenShutta(); } else { CloseShutta(); } } // We'll take advantage of the built in millis() timer that goes off // to keep track of time, and refresh the servo every 20 milliseconds // The SIGNAL(TIMER0_COMPA_vect) function is the interrupt that will be // Called by the microcontroller every 2 milliseconds volatile uint8_t counter = 0; SIGNAL(TIMER0_COMPA_vect) { // this gets called every 2 milliseconds counter += 1; // every 20 milliseconds, refresh the servos! if (counter >= 5) { counter = 0; myServo1.refresh(); } } // subroutine OpenShutta ******************************* void OpenShutta() { servoPos = OpenedValue; myServo1.write(servoPos); // tell servo to go to position digitalWrite(LEDPIN, HIGH); delay(200); // waits 1500ms for the servo to reach the position } // subroutine CloseShutta ******************************* void CloseShutta() { servoPos = ClosedValue; myServo1.write(servoPos); // tell servo to go to position digitalWrite(LEDPIN, LOW); delay(200); // waits 1500ms for the servo to reach the position } /* subroutine LEDdebug ******************************* Used to demonstrate some small value for debugging purposes by flashing Pin1 LED some number of times. */ void LEDdebug(int number) { for (int i=1; i <= number; i++) { digitalWrite(LEDPIN, HIGH); delay(500); digitalWrite(LEDPIN, LOW); delay(500); } }
