EZAD9850 Library
The EZAD9850 Library will get you up and running on the Arduino with inexpensive AD9850 based frequency generator modules.
This Arduino library makes easily available control of an AD9850 module's frequency and phase as well as starting and stopping frequency generation. Useful for a variety of radio projects and as a sine-wave generator. Operates from 0 - 40 MHz. It can be downloaded from https://github.com/r-ohare/EZAD9850
hillflyer wrote 07/02/2015 at 06:21 point
I have been playing with a module like this and I'd love to give your library a try. How can I download it? OK, found it on Github...
Mechanical Advantage wrote 07/03/2015 at 00:39 point
Cool, I added the URL to the description as well now. That one link all by itself isn't very obvious.
c.lamport wrote 04/30/2015 at 13:55 point
I'd love to incorporate this into a tACS machine, is there anymore information on this?
Mechanical Advantage wrote 04/30/2015 at 16:32 point
I'm not familiar with tACS. What's that all about?
c.lamport wrote 04/30/2015 at 16:47 point
tACS is similiar to tDCS (tACS is transcranial Alternating Current Stimulation, tDCS is transcranial Direct Current Stimulation) and it is for modulating long term potentiation in the brain. Basically, it brings the resting potential of the cells up so that it takes less stimulus for them to act (ie form a memory). DARPA even experimented with it. It was able to cut drone pilot training time in half, plus there's a multitude of other uses for it such as treatment of depression, increasing mathematical ability, focus, problem solving, memory, etc. (link here: http://www.scientificamerican.com/article/amping-up-brain-function/).
I built a simple, constant current (2mA which is what current research states should be used) tDCS machine. I've never posted any of my projects here but if you'd like I can upload the schematics, some pictures and references.
Mechanical Advantage wrote 05/02/2015 at 16:51 point
Wow. Well, I'm not familiar enough with that stuff to tell you one way or another but if you need something that will generate a low voltage sine wave between DC and 14 MHz (you can go higher but the wave get's messy) then you can pick up one of these boards off eBay for a few bucks and this library is super easy to use.
