1Step 1
Saw off 2 48 mm pieces of dowel rod
2Step 2
drill a hole 10 mm deep into one of the ends
3Step 3
Drill a hole through the side off the rod 7 mm from the end into which you have drilled the other hole
4Step 4
Clip off connector from the universal wall wart and strip the ends
5Step 5
Calculate 6 times 1.5 and set the voltage of the wall wart at that voltage.
6Step 6
Insert the wires into the holes you drilled across
7Step 7
8Step 8
9Step 9
10Step 10
richardginus
