Sensor upgrade
A project log for Homefront
A smartish home system with Arduino IoT devices and a Clojure cloud back-end with a web interface.
harri-ohra-ahoHarri Ohra-aho 04/11/2015 at 10:000 Comments
Considering replacing the HC-06 modules with ESP8266. The Bluetooth connection is extremely prone to failing. Even a slight change in the placement or orientation of the sender or receiver can cause a huge difference in reliability.
Also this change would get rid of the node.js middleman which is a huge bonus.
