Quick update
A project log for Open source sport/smart watch
Make Weloop Tommy an open source sport watch that can connect directly to all kind of sensors (heart rate monitor and so on)
KrzysiekKrzysiek 04/20/2015 at 22:256 Comments
I've just recorded watch upgrade process and will publish it in a few days. It's stable, I've added visual notification to be able to verify if everything was upgraded successfully.
HERE you can find a newest softdevice/bootloader installer. After flashing this firmware watch will restart and use the newest S120 2.0.0 softdevice. After that you can upload your custom firmware that can work as a peripheral or as a central device. I've also created a mock application to start writing firmware, source code for it can be found HERE.
DFU (bootloader) looks like this:
Test app:
And without backlight:
From now on I will focus on firmware functionality. Stay tuned!
mszewczy wrote 05/12/2017 at 21:53 point
nRF Connect for Mobile 4.11.1  from 12 V 2017  solves the problem of slow transfer on Android 7.  I installed it, but the problem is with Open Source smart watch (Unreleased) ...
Sean Su wrote 05/06/2015 at 03:02 point
No problem.  Enjoy your vacation. It's amazing the progress you've made in such a short time.
Krzysiek wrote 05/03/2015 at 19:05 point
I`m on vacation till the next Sunday so ufortunatelly no update to expect in the next week.
rai gondim wrote 05/03/2015 at 14:51 point
you are the best!
Waiting for your great work with the new firmware
Sean Su wrote 04/30/2015 at 20:57 point
You're doing gods work. A lot of people thought the Weloop tommy was done for, especially with the lower price of Pebble. Not exactly the case anymore. Thanks to you.
