Nothing to blog !
A project log for Cheap-dirty-perfect V-Groove Foam Cutter / Bender
A tool made in 15 minutes that will help you cut perfect V-Groove in polystyrene foam. The groove will help bend the foam.
ftreganftregan 03/05/2015 at 09:440 Comments
It took less than one hour from the idea to the second build I made (I made a second build so I can take pictures to document it). Nothing to blog, but the result is exactly what I wanted: cheap, made with thing I hade available here, it solves the problem with a perfect result.
