Mirror arm bearings.
A project log for Arcus-3D-P1 - Pick and Place for 3D printers
Open source, mostly 3D printable, lightweight pick and place head for a standard groove mount
daren-schwenkeDaren Schwenke 03/01/2018 at 18:340 Comments
Moved the bearings into the mirror arm.
Camera got moved up a bit and the optics adjusted, so if I decide to use a single solid shaft now for the Pi camera version, I could.
I also decided to go back to a non-adjustable mirror arm stop.  I didn't like the idea of snaking a screwdriver along the camera PCB to adjust it.  The stop is now printed as a vertical perimeter though so printable accuracy should be really good.
The most critical component positioning is that of the first mirror, so it gets a flat, top surface.  Actually, all the optical components mount to either completely vertical or horizontal surfaces for the same reason.
