One last look, before I go.
A project log for Arcus-3D-P1 - Pick and Place for 3D printers
Open source, mostly 3D printable, lightweight pick and place head for a standard groove mount
daren-schwenkeDaren Schwenke 08/29/2018 at 05:580 Comments
Thought I would share what the current mechanism for lifting the tape looks like, before it disappears forever into the void where uncommitted code goes to die.
The thin part was a living hinge, with the top of the T lifting up both the right edge of this tape and left edge of its neighbor.
The bottom of the T came down and intersected with the bands which provide the spring tension for the lever arm, stealing a bit of force to keep the tape held firmly up.
Alas, I think something which is perfectly at home in a little girl's hair will work better.  Goodnight sweet subtraction.
